1999 Pontiac Trans Am noise
150,000 MILES • V8 • 2WD • AUTOMATIC
LATRANSAM
I've been getting a metallic clicking noise from my drivetrain when shifting from P to R or D or any order of. It will also do it severly when you press the brakes and throttle at the same time (like powerbraking without turning tires over) rearend was just rebuilt in march and new u joints put in in april. but noise continues?????
May 21, 2010 at 3:09 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to visually inspect the trans mount, u-joints, rear end to see if anything has come loose or is broken.Did the noise ever go away after the rear end work was done?
May 25, 2010 at 1:02 AM
LATRANSAM
No the noise never went away. we have checked the new u-joints and rearend. also the same noise will occur if the car is pushed back and forth wile in park and not running. could it be the alum driveshaft?
May 28, 2010 at 11:21 AM
2CARPRO JACK
  • 11,533 POSTS
They tend to act like speakers for any noise in the drivetrain.Did you check the trans mount ane the suspension bar that goes fron tran to rear end to be sure all is good and tight? If so it may be excessive pinion play in the rear end
May 29, 2010 at 1:21 AM
