When I apply the brakes the low track light comes on and the anti lock brakes activate causing the brakes to pulsate.
Apr 25, 2010 at 6:29 AM
2CARPRO JACK
✓Experienced Mechanic
You will need to have the ABS/Traction control system scanned for trouble codes.The computer should have stored a fault code if it is activating they system every time you use the brakes.May just be a wheel speed sensor, but a scan should take the guess work out of it
