1998 Pontiac Trans Am Low Track light
1998 PONTIAC TRANS AM
196,000 MILES • V8 • 2WD • AUTOMATIC
KMCKEEGAN
When I apply the brakes the low track light comes on and the anti lock brakes activate causing the brakes to pulsate.
Apr 25, 2010 at 1:29 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
You will need to have the ABS/Traction control system scanned for trouble codes.The computer should have stored a fault code if it is activating they system every time you use the brakes.May just be a wheel speed sensor, but a scan should take the guess work out of it
Apr 26, 2010 at 11:49 AM
