1997 Pontiac Trans Am REPLACED FUEL PUMP, AND RELAY, STILL
106,000 MILES • V8 • 2WD • MANUAL
VICTORYGOGAN
I was driving my baby, and it died on me in second gear, got it to place, tried restarting wouldnt turn over, bough starting fluid and it started, check fuel rail no fuel, replaced relay, and pump checked fuel rail again, and no fuel squirted out. Pissed off, and irrated.
Dec 29, 2009 at 9:30 AM
MRBIGGDADDYWIGGS
I had a 96 T/A that had similar symptoms and after replacing everything that I thought it might be it ended up being the crank position sensor. I found that out when i had the Mechanic shop pick it up. it cost me 1100 dollars to get it fixed.
Jul 3, 2011 at 8:06 PM
