1995 Pontiac Trans Am harmonic balancer position
1995 PONTIAC TRANS AM
GARYGERLACH
Engine Mechanical problem
1995 Pontiac Trans Am V8 Two Wheel Drive Automatic
did not note position of arrow on balancer now dont know harmonic balancer position on crankshaft hub, no keyway , just three bolts.
Aug 31, 2010 at 11:58 AM
WRENCHTECH
  • 20,761 POSTS
see next post
Aug 31, 2010 at 12:04 PM
MADMIKE1735
  • 951 POSTS
it does matter where you place the damper....
CRANKSHAFT BALANCER AND HUB
Fig. 10 Crankshaft Damper & Hub Replacement
TOOL REQUIRED: J 39046 Crankshaft Hub Remover/Installer
REMOVE OR DISCONNECT
Raise and suitably support vehicle.
Serpentine drive belt.
Balancer bolts/screws and balancer assembly.
Match-marks crankshaft hub to engine front cover assembly.
Do not crank engine over after match-marking crankshaft hub and engine front cover assembly. Rotating crankshaft assembly will misalign installation of balancer assembly to crankshaft assembly possibly resulting in engine imbalance.
Crankshaft hub bolt/screw and washer.
Crankshaft hub using J 39046.
NOTE: The crankshaft hub can be installed by a different procedure if the engine should accidentally be cranked over after match-marking the hub and engine front cover assembly.
Set number 1 piston assembly to top dead center.
Install crankshaft hub with cast arrow on hub in the 12 o'clock position.
INSTALL OR CONNECT
Crankshaft hub washer and bolt/screws.
Crankshaft balancer assembly and bolt/screws.
IMPORTANT: If balancer assembly is replaced, new balance weights of the same size must be installed on the new balancer assembly in the same hole locations as the old balancer assembly.
TIGHTEN
Crankshaft balancer hub bolt/screw to 100 Nm (74 lb. ft.).
Crankshaft balancer bolts/screws to 85 Nm (63 lb. ft.).
Lower vehicle.
Aug 31, 2010 at 12:10 PM
GARYGERLACH
how can I get damper and crankshaft hub in right position are they marked someway?
Aug 31, 2010 at 12:24 PM
MADMIKE1735
  • 951 POSTS
you want to have cyl 1 at TDC.... usually, u can pull that plug, and hold your finger over the plug hole while someone slowly bars the engine over... when its at tdc, it will force your finger off the hole. however thats not as accurate as pulling your front timing cover, and verifying that your at TDC by timing marks.... once you know your at TDC, the arrow on the balancer points straight up... 12 oclock... hope this helps a bit.
Aug 31, 2010 at 12:28 PM
