1990 Pontiac Trans Am
1990 PONTIAC TRANS AM
JPREDIX
  • 6 POSTS
Engine Performance problem
1990 Pontiac Trans Am V8 Two Wheel Drive
push on throttle and lose power
Feb 24, 2010 at 9:07 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 24, 2010 at 9:14 AM
JPREDIX
  • 6 POSTS
you sent me alist of thing that might be wrong with my car and my garage fix everything and it still does it i will explain what it does. start car drive for 5 miles you go to punch it and feels like its flooding out
Mar 11, 2010 at 11:01 AM
Best start by checking fuel pressure if its within specs -
Mar 11, 2010 at 1:07 PM
JPREDIX
  • 6 POSTS
i had technician check that and everything checked out. Anything that has to do with fuel has been changed and is brand new. it is a new engine had local motor company put it in i have a lot of money tied up in the car and it still dont. I had several technicians look at it together they have over 100 years experience in this feild and not one could fix it
Mar 11, 2010 at 11:26 PM
Before I can continue I need the fuel pressure-both at idle and 2K rpm
Mar 12, 2010 at 6:25 AM
JPREDIX
  • 6 POSTS
45 idle 48 2k
Mar 12, 2010 at 6:34 AM
Did they check the knock sensor could be retarding ignition timing
Mar 12, 2010 at 6:51 AM
JPREDIX
  • 6 POSTS
would a code show up if thats the case
Mar 12, 2010 at 7:12 AM
Its suppose to work that way but at times they'll be a problem within the engine management system that the computer failed to lock-in and pop the CEL. Scan the computer again might give you something
Mar 12, 2010 at 7:39 AM
JPREDIX
  • 6 POSTS
well there was no codes that showed up i will try the knock sensor can i ask you where that is located thanks for everything i just want to get my car running and tired of paying mechcanic and still dont have a running car i hope i can find the problem because im going to take it back and show them i fixed it ha ha ha
Mar 12, 2010 at 7:57 AM
