2007 Pontiac Torrent Water in Trunk
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBIGELOW
I had parked my car outside for a couple of days and it rained non-stiop. I noticed a large amount of water under the cargo space where the spare tire is at. The dealer said the warranty does not cover leaks after 36K even though I have an extended warranty up to 100K. I do have a sun roof and I can't find any moisture inside the car - help me out on this
Feb 15, 2010 at 5:52 AM
RYANCOCO23
hi. i have that same car and i had the same problem. it turns out that the weather stripping around the liftgate has a factory fault. and the factory warrentry doesnt cover weather stripping after 36k, so if you have over 36k miles you have to pay for the fix yourself.
Mar 12, 2010 at 12:07 PM
