1991 Pontiac Tempest Stalling problem
1991 PONTIAC TEMPEST
155,000 MILES • 6 CYL • FWD • AUTOMATIC
TPSA01
When my car warms up it sporadically stalls when at a stop in drive. It has a rough idle when warm as well. If I put it into nuetral when at a stop it is fine.(little rough but not as bad). This only happens when it heats up. I will be replacing the theramostat, but doubt will be the solution. I have replaced the crankcase sensor which did not change anything. Help.
Jul 10, 2010 at 3:31 AM
Clean out the idle air control, EGR and PCV valves and test throttle position sensor-
Jul 10, 2010 at 10:34 AM
