2000 Pontiac Sunfire Coolant Leak Growl
ERENARD
My car is a pontiac sunfire 2000 with 196311 miles. I recently got a oil change, air filter, tune up, fuel injection cleaning, and replaced the serpentine belt. Two days later, there was a growling noise coming from the engine when the car was in idle. I noticed coolant coming from under the car after it had been parked for 15 minutes. The coolant resevior was full. Could this be my water pump? They also checked my hoses for leaks.
Feb 12, 2007 at 7:39 AM
MMPRINCE3000
  • 133 POSTS
More than likely considering the growling. Look at the WP, it has a "weep hole" on the casting if there is coolant there a seal or bearing is gone (or both) ant the pump will need to be replaced.
Feb 14, 2007 at 3:28 AM
Suggested Repair
Inspect the water pump weep hole for coolant. If coolant is present, the seal or bearing has failed and the water pump should be replaced.
Conversation Summary
A 2000 Pontiac Sunfire with high mileage developed a growling noise at idle and coolant leaking underneath after recent service, including a serpentine belt replacement. The coolant reservoir was full and the hoses had been checked. The expert said a failing water pump is likely and advised checking the weep hole; coolant there means the seal or bearing is bad and the pump needs replacement.
