2000 Pontiac Sunfire Won't Start
GURILLAZ
My 2000 Sunfire with 91,000 miles just quick working. The car will not turn over I jumped it to see if the batt was dead and got it running drove it around and was fine. Got home and turned it off and it would not start at all. All fuses are fine. People have said it is a lose alternator connection or a bad battery Any help is welcome and needed. Thanks
May 31, 2006 at 3:09 PM
SYNCRAIT
  • 235 POSTS
thats a good place to start check the connections mabe even test it with a multi meter checking resistance in the lines also chekc your alternator belt to make sure it isnt worn or loose
Jun 2, 2006 at 11:47 PM
GURILLAZ
All it was was an alternator Thanks guys
Jun 3, 2006 at 12:49 AM
Suggested Repair
Check battery and alternator connections, wiring resistance, and the alternator belt. The confirmed fault was a bad alternator, so test and replace the alternator if it is not charging.
Conversation Summary
A 2000 Pontiac Sunfire with 91,000 miles would not crank. Jumping it got it running, but it would not restart after being shut off. Fuses were fine. An expert suggested checking connections, wiring resistance, and the alternator belt. The owner later confirmed the problem was the alternator.
