1997 Pontiac Sunfire No Start
TRUSS
1997 Pontiac sunfire 2.4 with 100k mileage. Drove to work ,when pulling onto the parking lot I noticed kind of weird noises coming from inside the instrument panel area. I shut down the car and went to work. Came out apprx 9 hrs later. car turns over but won't start. An ob2 reading said cam and crank sensors,I have replaced the crank sensor,cam sensor,fuel pump,fuel filter,plugs wires,PCM, I even tried a different computer (in the right front wheel well) all to no success. I finally gave up on the car let it sit for a year. I started back on it last night, I recharged the battery and put the old computer back in,hooked the battery back up and tried to start it and it runs for about 10 minutes, makes that funny noise under the dash again and then dies now it will not run...what is going on...what do i do,helppppp....thx,todd addendum: we did a check with the ob2 and the codes read PO335 and PO342 hope this helps.
Jul 20, 2007 at 5:53 AM
2CARPRO JACK
  • 11,533 POSTS
Did the noise sound like relays clicking? Check all power feeds for good connection and check all grounds.
Jul 20, 2007 at 10:30 AM
TRUSS
[quote:993c8cc57b="2CarPro Jack"]Did the noise sound like relays clicking? Check all power feeds for good connection and check all grounds.[/quote:993c8cc57b]
Yes it sounds like a bunch of clicking and minor grinding going on inside the instrument panel and from a central location on the motor.
Jul 23, 2007 at 10:11 AM
2CARPRO JACK
  • 11,533 POSTS
In underhood power center, check with a meter for proper system voltage getting through all fuses.
Jul 24, 2007 at 12:59 AM
Suggested Repair
Check all power feeds and grounds for solid connections. In the underhood power center, use a meter to confirm proper system voltage is getting through all fuses. The dash noise may be relays clicking.
Conversation Summary
A 1997 Pontiac Sunfire 2.4 cranked but would not start after unusual noises from the instrument panel. Codes P0335 and P0342 were present. The crank sensor, cam sensor, fuel pump, fuel filter, plugs, wires, and PCM were replaced without a lasting fix. After sitting a year, it ran about 10 minutes, made clicking and minor grinding under the dash and at a central engine location, then died and would not restart. The expert advised checking power feeds, grounds, and voltage through all fuses in the underhood power center.
