when the temperature gauge reach the normal temperature in the middle it doesnt comes down and after that it says to check the oil and when it gets too hot it drops the antifrezze.
so i dont know what to do
can you help me?
Replace the thermostat and have the engine block tested for combustion gases entering the cooling system before any cooling-system pressure test. If those checks pass, pressure-test the radiator cap and inspect the radiator, cooling fans, hoses, and water pump.
A 1998 Pontiac Sunfire with a 2.4L engine overheats even after the radiator was cleaned and the water pump replaced. The cooling fan appears to work, the temperature stays high, the oil warning comes on, and coolant is expelled when the engine gets too hot. The expert recommends replacing the thermostat, testing the block for a combustion leak into the cooling system, and then checking the radiator cap, radiator, fans, hoses, and water pump if those tests pass. A pressure test should be avoided if a head-gasket leak is suspected.
