Overheating
GT_BALDO
  • PONTIAC SUNFIRE
Pontiac sunfire gt 1998 58,000 2.4l twin cam: my problem is that my engine is overheating and I dont know what to do, ive already clean the radiator, change the water pump for a new one, and its still overheating, there is no problem with the cooling fan or anithing related with that.
when the temperature gauge reach the normal temperature in the middle it doesnt comes down and after that it says to check the oil and when it gets too hot it drops the antifrezze.
so I dont know what to do
can you help me?
Friday, June 1st, 2007 AT 3:22 PM
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat, Pressure test the Rad. Cap, Clogged radiator, Fan clutch, Radiator electrical fan, collaspe hoses, water pump.
Friday, June 1st, 2007 AT 4:57 PM
