1996 Pontiac Sunfire Head Gasket Cost
SUNFIRE_GT
I have a '96 Sunfire GT, 2.4L Engine. About 150k.
Im having to replace the head gasket. Can you pls let me know just about how much it would cost me to have it professionally replaced? I normally do all my own repairs, but after replacing my water pump (6 Labor Hours) a couple of years ago, I really dont know if I wanna go through all that trouble again. If its cost effective enough, I'll just have a pro fix it.
Thanks!
Mark R.
Aug 13, 2007 at 3:09 PM
SERVICE WRITER
  • 9,123 POSTS
It varies for many reasons, talk to some local shops that come recommended. Just be SURE to compare apples to apples. Anything included in one shop that another isn't doing, like shaving the heads or pressure testing them, oil change etc. Would surprize me if it ran $800.
Aug 13, 2007 at 3:21 PM
Suggested Repair
Get quotes from recommended local shops and compare the same included work, such as head machining, pressure testing, and an oil change. Cost varies, but about $800 was suggested as a rough upper estimate.
Conversation Summary
The owner of a 1996 Pontiac Sunfire GT with a 2.4L engine and about 150,000 miles asked what a professional head gasket replacement would cost after previously replacing the water pump himself. The expert said prices vary and recommended comparing local shop quotes for identical included work, adding that it would be surprising if the job exceeded about $800.
