1998 Pontiac Sunfire Cranks No Start
1WOOKIEE420
A friend is giving me a 1998 Pontiac Sunfire if I can get it to start. He tells me that he replaced the ignition switch, but forgot to disconnect the battery before tinkering with the steering column. Now the car's engine will turn, but will not start at all. He thinks that he did something to the anti-theft device in the steering column. I've called several dealers, and they mostly say that I'm looking at a few hundred dollars at least. One dealership nearly two hours away said that he could plug something into the car and have it running right away, but I would have to bring the car to him. Any advice would be helpful.
Aug 18, 2007 at 6:26 PM
  • 75,988 POSTS
[quote:b9defe81e8="1wookiee420"]A friend is giving me a 1998 Pontiac Sunfire if I can get it to start. He tells me that he replaced the ignition switch, but forgot to disconnect the battery before tinkering with the steering column. Now the car's engine will turn, but will not start at all. He thinks that he did something to the anti-theft device in the steering column. I've called several dealers, and they mostly say that I'm looking at a few hundred dollars at least. One dealership nearly two hours away said that he could plug something into the car and have it running right away, but I would have to bring the car to him. Any advice would be helpful.[/quote:b9defe81e8]
When you turn key to On do you see all those idiot lights that suppose to come On. If not do below
Find the coil and check power at the positive terminal-no power get a jumper hook it on the pos. terminal and take it over to the battery positive post, now try to start it.
Aug 18, 2007 at 6:35 PM
Suggested Repair
With the key on, confirm the warning lights illuminate. If they do not, check for power at the ignition coil positive terminal. If there is no power, temporarily jumper battery positive to the coil positive terminal and try to start to see whether the no-start is a missing power feed after the ignition switch work.
Conversation Summary
A 1998 Pontiac Sunfire cranks but will not start after the ignition switch was replaced without disconnecting the battery. The owner suspects the steering-column anti-theft system and was quoted several hundred dollars by dealers. The expert asks whether the warning lights come on with the key on and, if not, advises checking power at the coil positive terminal and jumping battery positive to that terminal before trying to start.
