PLEASE HELP! Ok...I have a 96 Potiac Sunfire 2.2L. It started overheating about a month ago and since I have replaced the water pump, water neck (I had a bolt that siezed and couldn't remove the thermostat housing) and the thermostat. After this, it would still overheat. I thought the thermostat may be in backwards, so I tried to switch it but it only fit one way. The spring side is towards the block. I tried another thermostat thinking it may be a bad thermostat, still no go. It runs fine without the thermostat, but runs cool as expected. With the thermostat I also have no heat, but I have heat without it. Any help would be much appreciated!
Thanks.
Thanks.
Jan 20, 2006 at 5:28 AM
