2005 Pontiac Sunfire horn cover
STANTHEMAN44
how do you remove the horn cover on the steering wheel. cant get horn to work need to check wires
Apr 30, 2010 at 7:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the horn pad also contains the air bag. you need a special service tool to remove the driver air bag. disable the SIR system and remove trim cover. turn steering wheel until 2 of the 4 openings on the back of wheel are accessible. adjust and install special service tool to pull out the air bag / horn pad.
Apr 30, 2010 at 7:11 AM
