2005 Pontiac Sunfire horn cover
2005 PONTIAC SUNFIRE
STANTHEMAN44
how do you remove the horn cover on the steering wheel. cant get horn to work need to check wires
Apr 30, 2010 at 7:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the horn pad also contains the air bag. you need a special service tool to remove the driver air bag. disable the SIR system and remove trim cover. turn steering wheel until 2 of the 4 openings on the back of wheel are accessible. adjust and install special service tool to pull out the air bag / horn pad.
Apr 30, 2010 at 7:11 AM
