2005 Pontiac Sunfire Dashboard
2005 PONTIAC SUNFIRE
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAISEY45
I'm assuming this is something electrical?......The speedometer and rpm guage started going haywire.....now the temp guage is acting up.....the guages are all over the place......the gas guage has not been affected.....what do i need to do to get fixed.....also about the time all this started, the cruise control started acting up...that is...it will not hold, i can set it but it won't hold the speed for long...I was wondering if all of this is connected and what i need to do to get it fixed and if it will be very expensive to have fixed......Thank you for your answer.
Mae
Jan 5, 2010 at 12:52 PM
SERVICE WRITER
  • 9,123 POSTS
Pretty fair chance the instrument cluster needs replacement.
A quality shop should have a scan tool that can do a sweep test on the cluster to verify my suspicions. The cluster will need to pulled sent out and replaced. Typically a 2-3 turn around time with a price around $250-400 ball park.
Jan 6, 2010 at 8:59 PM
