2005 Pontiac Sunfire Back Up Lights
80,000 MILES • 4 CYL • 2WD • MANUAL
HEREWEOGAGAIN
The back up lights aren't working. The bulbs and the fuze are good. I am at a loss for what is wrong. The only thing that I can think of is that there might be a short in the system some place.
Jun 24, 2009 at 9:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Your Sunfire is equipped with a switch that controls the back-up lamps. From what you have described, this switch has failed, leaving the back-up lamp circuit permanently open (not working). You will need to replace your vehicle's back-up lamp switch, located on the left rear of the transaxle.
Thanks for using 2CarPros.com!
Jun 24, 2009 at 11:49 AM
