2005 Pontiac Sunfire Back Up Lights
HEREWEOGAGAIN
  • 2005 PONTIAC SUNFIRE
  • 4 CYL
  • MANUAL
  • 80,000 MILES
The back up lights aren't working. The bulbs and the fuze are good. I am at a loss for what is wrong. The only thing that I can think of is that there might be a short in the system some place.
Wednesday, June 24th, 2009 AT 4:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Your Sunfire is equipped with a switch that controls the back-up lamps. From what you have described, this switch has failed, leaving the back-up lamp circuit permanently open (not working). You will need to replace your vehicle's back-up lamp switch, located on the left rear of the transaxle.
Thanks for using 2CarPros. Com!
Wednesday, June 24th, 2009 AT 6:49 PM
