2005 Pontiac Sunfire 2005 Sunfire lacks power while acceler
39,000 MILES • 4 CYL • FWD • AUTOMATIC
SEBASTIAN007
I bought this car as salvage at auction. It has the 2.2 ecotec engine with 4 speed automatic transmission. It was in a frontal collision. Apart from the radiator/condenser the engine seemed untouched by the impact. I had the front unibody components straighened and a new rad support welded on- the frame shop did an excellent job.
The car starts perfectly and idles smooth but acceleration is very poor. I get a PO0300 multiple cylinder misfire when i drive it but if i clear the codes and
just idle, i get none. It behaves as if it's running too lean.
I've checked for air cleaner restrictions
spark plugs ( all 4 fouled with dry black deposits)
swapped the ignition module
Swapped ECM
replaced fuel filter
checked for leaks at intake manifold and throttle body
i have fuel pressure-just don't know how much
Sep 5, 2009 at 4:56 AM
  • 110,248 POSTS
If the plugs were black, it sounds like you are getting too much fuel. Was the temp sensor replaced?
Sep 7, 2009 at 3:49 PM
SEBASTIAN007
Well I got sick of guessing what the problem might be-took it to a dealer and they perfomed a back pressure test turn out the catlytic converter was plugged severly.
I thought it was either fuel pressure or back pressure but didn't have the tools to measure these.
Both the dealer and i agreed that it was rare for the catalytic converter to fail at such a kow milage but there was no warranty on it as it's a salvage vehicle.
It was worth the $122.00 for the diagnostics.
Thanks Jacob and Nickolas for your reply
Sep 18, 2009 at 7:25 AM
  • 110,248 POSTS
I'm glad you go it fixed. I didn't think of the converter because of the mileage. Keep an eye on things to see if it happens again. Something may have caused it.
Sep 18, 2009 at 12:11 PM
