2004 Pontiac Sunfire wheel bearing
2004 PONTIAC SUNFIRE
JASONF30
Tires and Wheels problem
2004 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
how do i change the wheel bearing on this year
Oct 19, 2008 at 10:54 AM
JNOVACK
  • 723 POSTS
make sure car is suported by jack stands and after removing wheel remove brakes remove caliper suport and rotor then with socket that fits large nut(approximently 30mm) remove nut push drive shaft through on back of spindle (were you pushed drive shaft) remove the 3 bolts and work the hub/bearing out and reinstall in reverse
Oct 19, 2008 at 11:09 AM
