i replaced all 4 struts ( complete strut assembly) i have a sqeaky noise coming from the rear driver side strut (up and down movement) these are gas struts. what can i do to fix this, also will i need a 2 or 4 wheel alignment,my mechanic said since this axle on the rear is dependent, a 2 wheel alignment should be good,any and all suggestions i woud appreciate. thanh you.
Oct 4, 2010 at 1:46 AM
