2004 Pontiac Sunfire
13,700 MILES • 4 CYL • FWD • AUTOMATIC
FISHER51
My car ran great then it stalled out and will not start!
Nov 13, 2009 at 8:12 PM
SERVICE WRITER
  • 9,123 POSTS
Are you out of gas?
Does it crank or do you get nothing when turning the key?
Nov 14, 2009 at 12:31 AM
FISHER51
yes it cranks, have plenty of gas in tank
Nov 14, 2009 at 1:08 AM
SERVICE WRITER
  • 9,123 POSTS
Try spraying some carb cleaner or starting fluid into the throttle body and then crank it, better to have someone crank it while you spray some in. This will help
tell if this is a lack of fuel loss problem.
We need to check for lack of fuel, spark and or compression.
Take a look at the "first things to check" section of our site menu.
Nov 14, 2009 at 2:26 AM
