2003 Pontiac Sunfire head lights
120,000 MILES • 4 CYL • FWD • AUTOMATIC
TICKEDOFF
I have a dim light and when I try the high beam the service indicator turns on.....is my light burning out on low beam as the high is out or is this a wiring issue?
Jan 18, 2008 at 10:32 AM
APPLE1
Wanting to know if you found out anything about your problem???
Jan 20, 2008 at 6:38 AM
MASTERTECHTIM
  • 4,750 POSTS
a dim light is caused by no ground.
Jan 20, 2008 at 6:46 AM
TICKEDOFF
Thanks for the reply. I have booked the appointment to find the problem with the ground.Well I'm back from my appointment! I had a corroded ground wire located under the wiper fluid tank. The tank had to be removed to fix this. The amount to find and fix at the dealership was almost 240.00. Hope this info helps.
Jan 20, 2008 at 7:51 PM
