2003 Pontiac Sunfire Engine temperature/Heater does not wor
2003 PONTIAC SUNFIRE
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
MMSWAN
I was driving last night about 30 mins on a highway. When I exited the highway I noticed my heater was no longer working (blowing out cold air) and my heat
gage was almost in the "red". The check engine light did not turn on. After inspecting under the hood I
found there to be plenty of coolant, the engine did
not seem hot (no smoke or heat radiating).
Additionally I did take notice to the serpentine belt and thought that it may be a bit loose. Do you have any ideas of what the underlying issue may be?
Feb 15, 2009 at 1:03 AM
  • 110,244 POSTS
Hi:
If the belt was loose, it wouldn't circulate the coolant which would cause you to loose heat and over heat the engine. Also, have you ever replaced the t'stat? It may be stuck shut and not allowing enough water flow.
Feb 20, 2009 at 11:43 AM
