2002 Pontiac sunfire won't take gas
TSTEWA03
My 2002 Pontiac sunfire suddenly does not take gas. We were almost on empty and tried to put gas in and it spit it back out. My husband used a snake type thing to see if someone had shoved anything in the tank and they had not. We can actually put gas in the tank however we have to put a little in and let it go down and then a little more etc. and it is taking us 20 minutes just to put $10 in which is no good at all. Do you know what this is and if so is it costly to fix?
Jun 19, 2007 at 6:53 AM
  • 55,588 POSTS
This problem happens from time to time becasue the rubber fill tube that connects the tank tot he fill pipe becomes internally separates which blocks the inlet. You will need to replace the hose with a new one to fix the problem.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
Mar 13, 2017 at 5:56 AM
