I changed my fuel filter & now it will not start. it is put on there the same way it was. It sounds like my car is out of gas. It will start with starter fluid but then will cut off when you hit the gas pedal. The fuel pump is making a working noise but it does not seem to be pumping out fuel. I did google & on a website, it stated VERY IMPORTANT. step 1. have the car running & have someone pull out the fuel pump fuse. THIS WAS NOT DONE. It stated something about pressure will build up. How do I fix this?
May 23, 2010 at 10:59 AM
