2001 Pontiac Sunfire
DAWNPICK
  • 2001 PONTIAC SUNFIRE
2001 Pontiac Sunfire 4 cyl Front Wheel Drive 163000 miles
2001 pontiac sunfire fuel pumps works but not getting gas to the fuel rail
Saturday, November 28th, 2009 AT 4:03 PM
JDL
  • 16,098 POSTS
Welcome to the forum, thanks for the donation. Just because you can hear the pump run, doesn't mean it will make pressure. You can take supply line loose from the fuel rail and also at the fuel filter, see if you can blow air through the line. Check the fuel filter, my info says it is located, under the vehicle, passenger-side rear. Fuel pressure 41--47psi. If good voltage and ground at the pump and the pump runs, no flow, suspect the pump.
Sunday, November 29th, 2009 AT 9:09 AM
