2002 Pontiac Sunfire Window Motors
CIEARRA
My window motors do no work any more and I bought replacement motors but I can not find a manuel to show me where I need to drill the rivets to replace the old motors
Nov 18, 2009 at 3:11 AM
KNOWYOURAUTO
  • 113 POSTS
Here is a diagram of the rivets that hold the regulator in place. The regulator should also be in this approximate position for easiest removal. Please keep in mind that the regulator is under tension, and once the motor is separated from it the spring will snap violently unless a a pair of vice grips is clamped onto the regulator arms.
https://images.2carpros.com/forum/automotive_pictures/435113_WindowRegulator2001sunfire_2.jpg
If you complete the job please post positive feedback. If you require more assistance please post back and we will continue to help. Good luck,
Nov 22, 2009 at 2:46 AM
