2002 Pontiac Sunfire - Where is the idle IAC sensor?
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
BSTEDWEL
I have a 2002 pontiac sunfire problem where the idle RPM Surges up and down when the A/C is engaged. It also sounds like the A/C clutch is cycling. I had the entire A/C System checked and it is fine. A/C blows very cold, no problems. It also seems to make a difference if you are in Park or if you are in Drive.
The mechanic who checked the A/C system could not find anything wrong with the electrical components or the A/C parts and blamed the problem on a defective PCM computer - Car was returned to me unrepaired.
I found other posts here that reported similar problems with sunfire and the best answers for a fix seemed to point to a dirty IAC sensor. They recommened taking it out and cleaning it, then replacing it.
My question is - Can you tell me where the Idle Air Control (IAC) valve/sensor is?
Also if you have another solution I would appreciate any suggestions.
Bruce
Apr 8, 2009 at 3:47 AM
BLACKOP555
  • 10,386 POSTS
the iac module is located on the throttle body by the butterfly valve. may have a sticker on it saying not to mess with idle speed.
Apr 8, 2009 at 3:11 PM
