2002 Pontiac Sunfire Slipping Transmission
13,100 MILES • 4 CYL • 2WD • AUTOMATIC
MARNOLD
When my car gets hot the transmission begans to slip while under a load. Diagnostic testing is not providing an answer to what the actaul problem is.
May 18, 2008 at 2:25 AM
  • 31,937 POSTS
Hi there,
You can only do so much your self... check the oil level and if that is OK, you will have to get advice from a transmission specialist as you will not be able to do ant serious home repairer on the transmission yourself.
Mark (mhpautos)
May 18, 2008 at 10:13 AM
