2002 Pontiac Sunfire reverse lights
2002 PONTIAC SUNFIRE
183,000 MILES • 4 CYL • FWD • MANUAL
MULLENS_SIDEKICK
every light works on the vehicle except the reverse lights. i think its the neutral safety switch but i dont know how to repair it.
Oct 27, 2009 at 12:31 PM
Turn key on -check fuse turn-B/U fuse 10amp in I/P fuse block if okay At the park and neutral switch on top of transaxle check for power at pink wire got power jumper it to the light green wire light should come on if not check the ground circuit below left front seat
Oct 27, 2009 at 1:00 PM
