2002 Pontiac Sunfire Remove Window Crank
60,000 MILES • 4 CYL • FWD • AUTOMATIC
JAVIER80
How do you remove the window crank on a 2002 Pontiac Sunfire? I am looking all over and there are a lot of logs referencing a pin, I do not see any pins on this crank. I read in one place that you just pull it off. Help!!
May 17, 2008 at 6:28 AM
PVOLTMER
I know its a little late, but if you didn't get it, the pin sets right behind the crank where it rests on the door panel. you have to push the door panel back and lay on the ground and take a small flat screwdriver and push the pin out. hope this helps!
Jun 27, 2008 at 10:05 PM
