2002 Pontiac Sunfire Radiator Fan
140,000 MILES • 4 CYL • FWD • AUTOMATIC
RKTHUMBS4
Radiator fan not working causing overheating in stall traffic....and AC as well of course...pulled connection wires to fan and measured -- no voltage...replaced relay and still the same results...
Jun 12, 2010 at 11:03 AM
  • 75,988 POSTS
Hi rkthumbs4, Welcome to 2carpros and TY for the donation Try powering both fans directly from the battery if both comes on -check below Your possibilities here could be one of the following are as follow the cooling fan fuse 30amp in underhood fuse block at left front of engine compartment, defective coolant temperature sensor and the computer-see below schematic diagram of the cooling system
https://images.2carpros.com/forum/automotive_pictures/12900_cooling_fans_3.jpg
Jun 13, 2010 at 12:27 AM
