2002 Pontiac Sunfire poor acceleration
2002 PONTIAC SUNFIRE
75,000 MILES • 4 CYL • FWD • MANUAL
SUNFIRE02
This car was running just fine. Then all at once one morning, it started stumbling badly under moderate acceleration. It comes back down to idle fine and idles realatively smooth. Under very light acceleration, it does okay. If I try to pull a hill it just starts stumbling & losing power. At a stop I noticed an unburned fuel type odor, like it may be running a bit rich. The check engine light flashed 3 times and then went out & stayed off. It just started this out of the blue. Any ideas? Thanks
Apr 10, 2008 at 9:07 AM
RHALL77
  • CAR REPAIR CONTRIBUTOR
  • 3,361 POSTS
you will have to have the PCM (powertrain control module) scanned and see what code is stored.
Apr 10, 2008 at 9:47 AM
CRYSTAL1992
It said censors and fuel pump.i have replaced i think everything but the motor and transmission
Jun 18, 2016 at 6:12 AM
