2002 Pontiac Sunfire DRL Headlights out,only have high beam
93,000 MILES • 4 CYL • FWD • AUTOMATIC
MSSUNFIRE
Hello,I have a 2002 Pontiac Sunfire, and just recently the Service Light came on,I didnt know what was going on till I discovered I had a dim light out,SO Then When I would start the car, put it in reverse or drive the headlights would flash 3-4 times, a clicking noise could be heard by the dash in side the car,and service light would come on,the the lights will go all out. HIGH beams work when turned on,But I have a dim out? Can some one please help. :oops: I know the light aint burnt out because when it flashes they both come on but then go off! Any Help would be greatly appriciated!!!!!!!! :lol:[img:9a4748516f]http://www.2carpros.com/forum/automotive_pictures/160972_S7300609_2.jpg[/img:9a4748516f]
Feb 21, 2008 at 8:58 AM
2CARPRO JACK
  • 11,533 POSTS
For starters have the PCM (computer) scanned for codes, Autozone will do it for free. If the PCM sees a problem it will store a code that will help in diagnosing the problem, get back with the exact codes.This may be the code from the BCM (body control module) telling us what is wrong.There is a fuse/relay panel behind lower left side of dash, see if it is the DRL relay that is clicking, might be weak
Feb 21, 2008 at 11:11 PM
