This car is not being driven much as my Daughter is deployed with the navy. The battery discharges very quickly, (a couple of days when not driven). I noticed when I pulled the cables off to clean them that there was a significant current draw with every thing turned off and the ignition off. It is approximately a 3 amp draw. I pulled fuses until the draw stopped, and it was the instrument cluster fuse that stopped the current draw. With the fuse in, disconnecting and reconnecting the battery causes an audible "click" like a relay closing.
Should there be any current draw on the battery with everything turned off?
Both the battery and the alternator were replaced a couple of years ago with a 96 month battery and a Delco reman alternator.
Apr 20, 2008 at 12:31 PM
