Blinker flasher relay location
BROOKE_JONES
Where is the blinker flasher relay located?
May 25, 2010 at 1:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The blinker flasher module is number one in picture below. it is on the brake pedal bracket, below driver side dash.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_532.jpg
Please let us know if you need anything else to get the problem fixed. Cheers
May 25, 2010 at 1:59 PM
2CP-ARCHIVES
  • 4,540 POSTS
blinkers wont work. Flashers do. Where is the flasher located?
Jun 25, 2019 at 7:02 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
It's attached to a bracket on the right side of the frame that the brake pedal hangs from, however it is a combination flasher for both hazards and turn signals so it may not be your problem.
DOUG BECK
wheres the flasher located on the car flasher for the blinkers
JSKELLY4693
  • 22 POSTS
Actually, it's a relay. It should be located on the top of the steering column. I can't remember if it's in front or behind the Hazard light switch.
To take off the plastic cover, you will need a long Phillips screwdriver. Under the lower plastic cover (ignition key), there should be three holes under there. Either 2 up front and on in back, or vise-versa. Loosen all three screws, and pull the top cover up (you may have to pull a little hard, or use a flat head screwdriver to pop the plastic, but be careful, you don't want to scratch it up).
Once you have the top cover off, look for the relay.
