2002 Pontiac Sunfire at freeway speed, car jumps up a gear
2002 PONTIAC SUNFIRE
TIKA1979
Engine Performance problem
2002 Pontiac Sunfire Front Wheel Drive Automatic 175000 miles
at freeway speed the transmission seems to jump up a gear than back,and continues vairously while on the freeway. It also does this when im in town driving giving me the same problems. I changed fuel filter, plugs, wires, replaced a bad wire in the front wheel sensor, rear brake wheel cylinder and brakes they were so bad they had to be torched and beat off im not sure if that caused any damage or not but it seems fine. No other lights are on indacating any problems. I do all of my one repairs this one just has me stumped although i did take it in for the rear brakes.
Apr 1, 2009 at 2:00 PM
JAMES W.
  • 2,394 POSTS
I would take a serious look at the throttle position sensor. You can tast this with an ohm meter to make sure the rise and fall in the meter reading is smooth. You may find a "dead" spot in it.
Apr 2, 2009 at 8:55 AM
TIKA1979
I was just wondering if it were the TPS wouldnt that trip the service light? I will check that out tomorrow and let you know what i come up with, thanks
Apr 2, 2009 at 1:44 PM
JAMES W.
  • 2,394 POSTS
Not always. Sometimes a failure happens so fast the ECM doesn't pick it up as a problem.
Apr 2, 2009 at 1:51 PM
TIKA1979
Just wanted to let you know that my problem was in fact the TPS the spring was broke causing it to jump all over on the ohm meter. Thanks for all of your help i will use this service again and also recommend this service to my friends. Thanks
Apr 4, 2009 at 2:17 AM
JAMES W.
  • 2,394 POSTS
Glad you found it. Anything else, you know where to find us.
Apr 4, 2009 at 5:55 AM
