2002 Pontiac Sunfire 2002 pontiac wont
120,000 MILES • 4 CYL • 2WD • MANUAL
TSANITY69
when i put my 2002 sunfire into gear it doesn't move. The engine revs and it rolls in whatever direction the shifter is in... forward in gears 1-5... backwards in reverse... i've tried all gears with the same results.
Feb 12, 2009 at 1:06 AM
MMPRINCE4000
  • 8,548 POSTS
Check the shifter cables for broken brackets, loose connections, but it sounds more like a bad clutch.
When replacing clutch, ALWAYS have rear main seal on engine replaced, resurface flywheel or get a new one.
Feb 12, 2009 at 11:13 PM
