2002 Pontiac Sunfire
147,000 MILES • 4 CYL • 2WD • AUTOMATIC
WEVB13
I have a promblem with the brake lights, blicker lights and hasard lights not coming on. I have check the fuses. They were working untill last night.
Sep 16, 2010 at 5:27 AM
WRENCHTECH
  • 20,760 POSTS
Is the 3rd (high mount) brake light working?
Sep 16, 2010 at 6:27 AM
WEVB13
NO, I don't believe there is one.
Sep 16, 2010 at 11:07 AM
WRENCHTECH
  • 20,760 POSTS
Yes, there is. It's required by law.
Sep 16, 2010 at 11:21 AM
WEVB13
yes your right. It don't way.
Sep 17, 2010 at 1:24 AM
WRENCHTECH
  • 20,760 POSTS
It appears your saying the high mount light doesn't work.
Everything your saying is not adding up correctly.
The lower brake lights and turn signals all run through the turn signal switch so this would be the likely suspect for your problem, however the high mount does not follow that patch and works directly from the brake light switch so your going to have to do some testing. Test for power coming into the brake light switch constant and going back out when the brake is applied. You could have had issues with the high mounts before this.
Sep 17, 2010 at 1:34 AM
WEVB13
Where is the signal relay located. I will try that first.
Sep 17, 2010 at 4:13 AM
WRENCHTECH
  • 20,760 POSTS
That would have nothing at all to do with brake lights.
It's mounted to a bracket above the brake pedal.
Sep 17, 2010 at 4:16 AM
