2001 Pontiac Sunfire Turn signal does not work
70,000 MILES • 4 CYL • FWD • AUTOMATIC
DETTLING
On my 2001 sunfire the turn signal stop working, when I turn the switch, the light on the dash comes on once and then off, does not flash. Same for both sides.
Mar 18, 2009 at 12:25 PM
EUGENE123
  • 273 POSTS
check your turn signal bulbs and check your fuses
Mar 18, 2009 at 12:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty flasher unit. Flasher is located in front seating area, driver side, under dash, mounted on top of brake pedal .
Thanks for using 2CarPros.com!
Mar 19, 2009 at 10:27 AM
