2001 Pontiac Sunfire TCC PWM Solenoid replacement
2001 PONTIAC SUNFIRE
70,000 MILES • 4 CYL • FWD • AUTOMATIC
SILENTWATCH
I have a 2001 Pontiac Sunfire 4cyl 4spd auto and is it possible to replace the Torque Converter Clutch Pulse Width Modulation (TCC PWM) solenoid without removing the transmission from the car? Also when I do remove the side cover of the transmission where is the solenoid located? Thanks...
Sep 10, 2010 at 4:42 AM
DOCFIXIT
  • 18,828 POSTS
Located on valve body need to remove pan see diagram
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_612.jpg
Sep 10, 2010 at 6:08 AM
