2001 Pontiac Sunfire side mirror replacement
54,000 MILES • 4 CYL • FWD • AUTOMATIC
MARMADUKE
I need to replace the drivers side mirror. 4 door sedan. Mirror appears to be mounted above the door right into window. Before I order and attempt repairs, do you know if I would have to remove interior door panel? Mirror is manual remote.
Mar 2, 2008 at 11:45 PM
SERVICE WRITER
  • 9,123 POSTS
I have a 2 door and mine does not require panal removal. There is a screw that holds a trim piece on that will expose the retaining screw. Not sure of the 4 door.
Mar 2, 2008 at 11:55 PM
