2001 Pontiac Sunfire Rear defrost relay
2001 PONTIAC SUNFIRE
BANDF
Electrical problem
2001 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
I'm trying to find out where the rear defrost relay is in my car. The reason is, my rear defrost is not working. I've tested the wires at the grid...no power, the connectors are firmly attached to the grid. I've checked the fuse it is good. When I push the power button on the little yellow light lights up. Is the relay separate from the power button or is it all one unit. Either way I will need to know how to get at part.
Thanks in advance
Dec 22, 2009 at 1:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
there is no relay. if fuse and wiring is good then suspect faulty switch.
Dec 26, 2009 at 1:54 PM
