2001 Pontiac Sunfire Brake lights not working
2001 PONTIAC SUNFIRE
68,000 MILES • 4 CYL • FWD • AUTOMATIC
GREENEYEDLADY03
The two side brake lights do not work but the middle one does. The tail lights also work. The fuses and the bulbs have been checked and are okay.
Jan 26, 2008 at 12:25 PM
BMRFIXIT
  • 19,053 POSTS
[quote:0ff3cb0f3a="greeneyedlady03"]Brakes problem
2001 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic 68000 miles
The two side brake lights do not work but the middle one does. The tail lights also work. The fuses and the bulbs have been checked and are okay.[/quote:0ff3cb0f3a]
And you don’t have signals too
check bulbs make sure you have the correct bulbs
if all OK
signal switch no good
Jan 26, 2008 at 1:20 PM
