2001 Pontiac Sunfire Brake lights and turn signals not work
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
GOJIDUO
2001 pontiac sufire. Brake lights out. (Tail lights work) turnsignals no longer work, Powerlocks don't work. no hazard lights. fuses all good inside car at dash side. What could cause the turn signals and brake lights not to work? Car was left for onw eek heavy rain then car had these problems.
Thank you ahead for your respnse
Chris
Mar 18, 2008 at 2:15 AM
GOJIDUO
I would like to add that the light bulbs around the car have been checked and replaced and all work with proper replacement bulbs.
Mar 18, 2008 at 2:18 AM
MIKE H R
  • 3,094 POSTS
not sure but i think there is a fuseable link under the hood it should be on the drivers side. There should also be other fuses in there check with tester to make sure a fuseable link had not gotten wet and shorted out.
Mar 18, 2008 at 3:08 AM
MASTERTECHTIM
  • 4,750 POSTS
ONE MORE THING TO CHECK IS ACTUALLY SEE IF YOU HAVE POWER AT BRAKE LIGHT SWITCH, IF YOU DO THE TURN SIGNAL SWITCH IS BAD. THE BRAKE LIGHTS RUN THROUGH THE TURN SIGNAL SWITCH BEFORE GOING TO REAR LIGHTS. ITS KIND OF A TELL TALE THE TURN SIGNAL SWITCH IS BAD WHEN BOTH BRAKLE LIGHTS AND TURN SIGNALS DONT WORK. GET BACK TO US
Mar 18, 2008 at 4:00 AM
GOJIDUO
Sorry to be a bother I know where ther fuses are under the hood. How would I find the fusable link there? Also what should the readings be on a multi meter to make sure they work? Same for the rear tail lights what is the multi meter reading?
Thanks again and this has definately helped alot.
Mar 18, 2008 at 7:14 AM
MIKE H R
  • 3,094 POSTS
The fuseable link looks like a short piece of wire,that sticks up making a loop in the fuse box. both ends would have a male ends. The wire might be only an inch to 2 inches long. If there is too much of a drain in one curcuit. If it uses too much voltage the middle of the wire melts. If there is one there it would be around the fuses.
Mar 19, 2008 at 11:02 AM
MARTIDEE
Chris[/quote]
Sep 29, 2008 at 4:52 PM
MARTIDEE
I just had the same problem with my 97 sunfire. There is a switch above the the brake. You will need to unscrew the small panel to have access to the switch. There is a part like a relay switch that controls the brake lights and blinkers. My 97 had two of them. I replaced them for $8.00 each plus tax. All is working fine.
Sep 29, 2008 at 4:56 PM
