2001 Pontiac Sunfire 2001 Sunfire Power Window Relay?
98,765 MILES • 4 CYL • FWD • AUTOMATIC
REDEFIRE75
I lost power to two of my windows, front passenger and rear driver's. It is a four-door, if that matters, as far as the back one goes. All the connections test out okay. My friend said to check the relays but I have no clue where they are.
May 24, 2010 at 4:39 AM
  • 75,988 POSTS
There's no relays -Test the master window switch your problem is coming from there.
https://images.2carpros.com/forum/automotive_pictures/12900_window_6.jpg
May 24, 2010 at 10:34 PM
XEKON
Thanks, once I knew there was no relays I just checked for power at the wires while somebody pressed up and down on the switches, was a short in one of the two wires to my drivers window motor, ran a new wire and now it works great.
PS: pictures to small to read the text, but thanks all the same :)
Mar 27, 2013 at 5:48 PM
